Viper clutching for SLP triple pipes
sadlerracing529
Hello,
I have a 2002 sx viper that I am going through and adding SLP triple pipes and have a clutching question.
What will the following from SLP do for me? (just seems very mild and I would think there has to be something better)
I am new to messing with clutching. I have the Aaen clutching book, but have not had the chance to read through it yet.
SLP calls for the following RPM
Power Peak: 8900 RPM
Minimum Running RPM: 8700 RPM
Maximum Running RPM: 9000 RPM
SLP recommends for 0-3000 ft elevation
shift weights:
8 EK
13.9mm steel rivet
inner hole
13.9mm steel rivet
outer hole
Primary spring:
yellow-white-yellow (stock)
Secondary cam:
47* (stock)
Secondary spring:
Red (stock)
70 Preload,
Setting 1-6
Gearing:
22/38
I see alot of set-ups of guys running the 40-10 Heel clickers for piped Vipers but I am having problems sourcing this kit and they are out of production, so looking for some advice or set ups that I can do for a non heel clicker kit.
Thank you
Did you reach out to thunder products?. I'm sure they can help you out with a heavy hitter setup. I used 48 gram heavy hitters back when i had my piped viper. Different pipes(cpr) but it was good.
Curious, what did SLP say about your set up, Did they give you any recommendations?... Or no contact... ✌️ ✌️🐒
