NorthofSixty
Need a little help finding a part number. I was looking for the for the typical alignment shim/washer that goes between the back of the secondary and the jackshaft bearing on my 99 Venture 700. The service manual shows one but it does not show up on the part diagram. It does not show up on the parts diagram for this model in other years either. Does anyone know if there is supposed to be one and the part number. Thanks
Cant tell ya if its supposed to have one but I can give you the part #s.
90201-252F1-00-00 .5mm thick
90201-25527-00-00 1mm
90201-25526-00-00 2mm
