Underhood snow build up Viper 700
  • Check hood fit, both on belly pan and airbox.
  • Make sure hood parts are not broken.
  • Block off vents below bumper when in powder.
  • Run a fine mesh filter over the foam on the airbox or consider blocking off induction scoops beside the headlights.
  • Use mountain skis. This was a huge difference.
  • I also found an exhaust deflector necessary to avoid bogging.
"Ram air" vents are blocked off already.
Used frogzskin on big vent in front of exhaust pipe, and used smaller pieces on the hood side of the intake.
Did nothing literally 5 minutes in powder and it was un-rideable, air filter completely plugged with snow.
This is ridiculous as it's a "mountain Viper" . How did Yamaha ever get away with this BS back in the day. Bone stock low mileage sled aside from a trail can. Already has wide mountain skis from previous owner.
I'll try the outerwears thing but haven't heard of the Exhaust deflector. Could you elaborate on that one? Thanks for the replies.1000043001.jpg1000043002.jpg1000043003.jpg
Is yours a true mtn viper or an extended shorty? Many differences between the two as to air intake. The exhaust deflector is Yamaha part# 8EN-2194H-00-00. No longer available, I tried to buy the last one out of Japan last year and someone beat me to it. I have an 03 and an 05, stock exhaust, and never had the issues your experiencing and we ride mountains and powder. 8EN should be the prefix on your vin for the mtn model, not sure for Canada
Yes, factory MTN. Not extended.
Your sled should have the deflector from the factory, check and see. They can dislodge themselves. I see you have an aftermarket silencer and I am a firm believer in sealing the exit hole with high temp silicone, stock or aftermarket. Shine a light up from below and see how much it isnt sealing and check the rivets and fitment on the bellypan seems. Looks like snow is packing heavily in that are. I may have a pre-filter available if you cant find one.
Is the rubber grommet missing or not sealing around the exhaust outlet. In powder it will force snow back in the belly pan from the exhaust because it has no where to go. A deflector helps, but sealing that off is key. Tighter screens that fit well may also help.
kirkswim's 02 viper looked like this after powder riding on the lake in stock form. it was literally dripping water into the air box from the filter. put the outerwears in and mtx skis on it and had no issues with it when powder riding. i had to fix the hole on dad's for exh as it moved and melted the belly pan and was letting snow in on the trail. pop rivits and silicone on a peice of galvanized metal got it re seized and fixed right up.
That prefilter is great. I added 4 zip ties (1 in each corner) to keep it in place. I had the same issue you are having when the exhaust outlet grommet was displaced. When I sealed the exhaust outlet to the belly pan, as the previous poster suggested, most of the problem went away. I believe my sled is very similar to yours, and will post a picture...
The exhaust can I have is perfectly sealed to the belly pan. Checked with a flashlight underneath. Soft fresh was powder pouring in through the hood vents. Will try again this weekend we got another boatload of snow in central Sask.1000045784.jpg
Also what skid is that in your sled? Something down the road I'd like to do.
