Results 1 to 8 of 8
Thread: My First V-Max 4
  1. #1
    Member Mini phazernut's Avatar
    Join Date
    Feb 2007
    Torbay, Newfoundland
    Posts
    38
    Default My First V-Max 4
    Well it took me 21 years of wanting one. Finally found one a couple of weeks ago. All Stock 96 with 7700km on it. Love the sound of that quad. My young fella in my Avitar now rides the Viper. Long way from the Sno Scoot
    Attached Images Attached Images
  2. #2
    Member Mini AttakMax's Avatar
    Join Date
    Jan 2007
    Corner Brook, NL, Canada
    Posts
    46
    Default
    That sled came from the West Coast. It was laid up for a few years. The guy who finally bought it got it for a song. I missed out on it by a few days. It has changed hands a few times since. Nice sled.
  3. #3
    Senior Member Improved low slung's Avatar
    Join Date
    Feb 2005
    Newfoundland
    Posts
    394
    Default
    Congrats on that find,too bad were getting one rain soaked of a winter here the past month.Heres a Forum that will come in handy http://www.vmax4.com/content.php? Only ever saw one Vmax 4 in my life and that was 1996 in the old yamaha dealer before you got to avalon ford.There rare as hens teeth
  4. #4
    Senior Member Stock Woody255's Avatar
    Join Date
    Jan 2016
    NW Ontario
    Posts
    129
    Default
    Be careful....they are addictive! Enjoy that V4. Pull the white collars/tabs from the airboxes if you haven't already.
  5. #5
    Senior Member Open Mod norwegian's Avatar
    Join Date
    Nov 2004
    norway
    Posts
    2,346
    Default
    Why pull the white collars/tabs?
    See the whole waterskipping at http://www.elgen.net/veivisr/srx-shooting2.wmv
    Stating the obvious is not neccesary!
  6. #6
    Join Date
    Jun 2007
    Burlington Wi.
    Posts
    1,015
    Default
    The collars get brittle with age, then the tabs will break off. If you are lucky they will hang a carb open, set off the TORS (if it isn't bypassed and you will find the problem. If you aren't lucky and one breaks on a WOT run it can/will get ingested into the crankcase destroying parts in the process. Broken piston, bent rod, junked cylinder, head crankcase.
    Potentially catastrophic. I bought one that broke a piston bad enough that the rod shoved a big piece of it back through the reed cage, bent the rod, broke out the bottom of the case and still ran. The guy limped in home on 3 but ended up wreaking the adjoining cylinder because it was ingesting debris thrown into the airbox from the fist one's coming apart.
    Break the tabs off, leave the white tube/collar in. The airbox boot's clamp will hold the collar in and it will run fine.
    opsled
    I reserve the right to change my mind if someone can prove to me it needs replacing.
  7. #7
    Join Date
    Jan 2016
    NW Ontario
    Posts
    129
    Default
    Yeah.... what opsled said. Lol. In all seriousness, get rid of them. Big problems will arise someday if you don't. Enjoy the Vmax4. Still nothing else like them.
  8. #8
    Dimebag Darrell RIP vmax4rules's Avatar
    Join Date
    Aug 2004
    The " Buckle" of the NWL MI LES belt!
    Posts
    398
    Default
    Congrats!
    1992 VMAX-4 W/PSI QUADS
    Current mileage 25,505
    1997 VMAX 700SX W/POWER INC TRIPLES
Posting Permissions
  • You may not post replies
  • You may not edit your posts
