Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: 2000 srx against the 850 doo?
  1. #1
    Junior Member Mini
    Join Date
    Sep 2017
    Ontario,Canada
    Posts
    5
    Default 2000 srx against the 850 doo?
    Both stock how do ya figure it will end?
    Lake run lots of room. I personally dont think a 850 will do 120mph but...
  2. #2
    Junior Member Mini
    Join Date
    Sep 2017
    Ontario,Canada
    Posts
    5
    Default
    Then the 1200 4 stoke is next.
  3. #3
    VIP Lifetime Member blevis213's Avatar
    Join Date
    Mar 2012
    new york
    Posts
    274
    Default
    I can tell you first hand that a 850 will do 116 stock with my 185 lbs on it, i raced that same sled with my apex and he beat me my sled has ulmer clutching so its good i've got 114 on gps. People say my sled needs more miles to break in though, 700 miles.I'll try it again after 1000 miles.
    2004 viper s hauck/cpr venom kit-mine
    2014 apex se with hauck silencer, excell idler wheels, tricked-toys rear wheels, ulmers airbox mod,programmer, and clutching-mine
    2001 sx500r stock- daughters
    2002 sx600r drilled can-wifes
    2000 srx stock-spare
  4. #4
    Default
    Get a good hole shot and race 400 feet. By then you might be seeing tail lights. Not that my SRX is the best and I'm sure I need to work it more to be closer to the 850. But I ride 85% trail
    2001 SRX 700 Mine
    8DN 20's
    4.5 mid
    5.5 tip
    secondary green at 70
    Dalton 56/44
    2004 Yamaha Venom Wife's new sled
    2003 120 ZR Sons
    Studded.
    Sons New Ride
    2012 Phazer RTX.
  5. #5
    Senior Member Open Mod needaSRX's Avatar
    Join Date
    Jan 2008
    Manitoba
    Posts
    1,522
    Default
    Stock for stock the 850 will get you, they have the hp and they're lite
    You'll have a better Chance at a longer distance and clutch for it
    WOW!!!!........Even fast said that was F@*Kin! fast
    One day you will see you and your snowmobile flash before your eyes: make sure it's worth watching!
    2000 SRX 700
    Unless you're part of the new generation that thinks only new is cool. Then I can't help you. I don't spend money to get looked at. I spend money to put a smile on my own face....
  6. #6
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    2,839
    Default
    4 strokes need over 2000mi before they start to wake up usually.
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  7. #7
    Default
    Quote Originally Posted by Maim View Post
    Thank goodness There is my answer. I had to totally reclutch my 2011 Apex until it breaks in. Still oy 1500 miles on it. Bought it new in 2014 as a left over
  8. #8
    Default
    You might even want to go up a tooth on top and clutch for it.
  9. #9
    Default
    24/38 gearing? what clutching would you use for that?
    2001 SRX 700 Mine
    8DN 20's
    4.5 mid
    5.5 tip
    Dalton 56/44
    2003 120 ZR Sons
    Studded.
    Sons New Ride
    2012 Phazer RTX.
  10. #10
    Senior Member Open Mod shaggyzr2's Avatar
    Join Date
    Dec 2011
    Central Wisconsin
    Posts
    1,770
    Default
Posting Permissions
  • You may not post replies
  • You may not edit your posts
