Results 1 to 7 of 7
Thread: Mm 700 Power Inc jetting for 8,000-10,000ft.
  1. #1
    Exclamation Mm 700 Power Inc jetting for 8,000-10,000ft.
    I have a 2000 MTN Max, ported and polished engine with power inc end dump pipes and air box mod. I know these pipes run at 8500 rpms. I need an idea for jetting at 8-10k feet. I tried 138.3 PTO and 140's but won't pull the rpms, I tried nocking weight out of the primary but didn't change the rpms. Need some advice.
  2. #2
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    2,850
    Default
    what do the plugs look like at rpm?
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  3. #3
    Default
    Quote Originally Posted by Maim View Post
    The plugs are dark brown.
  4. #4
    VIP Member A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,294
    Dannyboy
  5. #5
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    2,850
    Default
    a touch ritch but not too bad. reeds are in good shape? air box all stock?
    sleds
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  6. #6
    Default
    I have the air box mod, holes in the mid plate. And the reeds are good.
  7. #7
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    2,850
    Default
    primary spring might be too stiff for your clutching. i am by no means a clutching expert but it might be asking for a softer spring. are you using power inc clutching reccomendadions as a base without the porting?
    sleds
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
Posting Permissions
  • You may not post replies
  • You may not edit your posts
