Results 1 to 7 of 7
Thread: Got a 1995 phaser 2 le
  1. #1
    Member Mini
    Join Date
    Dec 2010
    Rice lake wisconsin
    Posts
    97
    Thumbs up Got a 1995 phaser 2 le
    Hello all sold my 700sx a while back got a low mile 1349 mile project :winterru. It needs some tlcbut I'm getting her squared away I always wanted a light quick smaller sled so I got this for 200.00 anything to look out for with the phaser thanks
  2. #2
    Member Mini
    Join Date
    Dec 2010
    Rice lake wisconsin
    Posts
    97
    Default
    I guess nobody knows anything about phazers oh well!
  3. #3
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,190
    1 out of 1 members found this post helpful.
    Default
    check that the carb up-date was done to it. they had a problem of being lean in the mid range while riding and burning up.
    other than obvious crank seals, carb boots and fan belt/bearings and obvious maintence items, those are a good sled.
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  4. #4
    Member Mini
    Join Date
    Dec 2010
    Rice lake wisconsin
    Posts
    97
    Default
    Thanks Maim! Carb update is that the nozzle one that is sticking up out of the throat of the carb right?
  5. #5
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,190
    Default
    i do not know exactly what was replace but i do know about the up date as a brother had to do the research for a sled he had bought.
    sleds
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  6. #6
    Member Mini
    Join Date
    Dec 2010
    Rice lake wisconsin
    Posts
    97
    Default
    I checked my nozzles they are 3a 143 main jets pilots couldn't tell lol I cleaned and inspected everything in my carbs all passages are clear can see light through spray comes flying out 3a are about middle according to the chart on the upgrade could I go one size up on my main to richen it up a bit?
  7. #7
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,190
    Default
    if the plugs are brown on a wot throttle chop ( shut the sled down while going wide open and remove plugs right away before re starting motor) i would leave it alone and run it.
    sleds
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
Posting Permissions
  • You may not post replies
  • You may not edit your posts
