Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Thread: Years with Yamaha SXViper
  1. #11
    Default
    Some updates for this season. First ride of the season wasn't succes. I crashed again... This time only shock mount bolt failed.
    Here is video, but there nothing special on trail ride.
    Then i found some triple pipes on this forum and bought them.
    Here you can difference between hauck bigbore pipes manifold and speedwerx pipes manifolds. Lot of better design on speedwerx.
    Also installed custom engine mount, made from icehockey Same time adjusted a little my diy torque arm.
    And opticool headgasget ofc
    Rear cooler and running board protective tube assembled
    Yamaha SXViper 2002
    2" riser
    44" stance
    Blue headlight cover
    DIY windshield
    18.9" fox floats on front end and 18.7" fox float on rear skid
    Tunnel stiffeners and protective tube
  2. #12
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,545
    Default
    Ya know that the third crash is a charm.
    Dannyboy
  3. #13
    Post
    Quote Originally Posted by A couple of bucks View Post
    Hahah
    Well, speed corrects errors so it was time to get more power to this beast.
    Those speedwerx triples fit pretty good with reverse. I need to relocate battery, because pipes take a lot of space.
    Changed weighs to 8dn if i remember right, stock clutch sping with shim. Secondary spring also changed, but i have no idea what it is, all marks are gone.
    Changed mainjets to 165, i have to change pilotjets, but it is hard to get them so i'm still waiting my order..
    First test ride wasn't succes, sled bogs with full throtle. I have to figure out why...
    But couple pics, because pictures are nice.
    It is pretty tight, but it fits.
    And something special, can you guess?
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  4. #14
    Join Date
    Jan 2009
    Posts
    5,545
    Default
    Steering related bushing??
    Dannyboy
  5. #15
    Default
    Nope, those are bushing for shocks. For stock front shock and others to fox float. I have seen couple pics of fox float mod to pro-action, but i don't know how they create mounting.
    That's why i decided to make some special bushing.
    Everything started here
    And here is outcome, with some billet wheels
    I have no idea how much i have to use pressure on that float shock, but it will become clear by testing.
    I think that there is different shimming on that rear skid fox float because, shock is much more sensitive on high pressures vers front floats.
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  6. #16
    Default
    Hello,
    Some update for this tread.
    Last winter sled worked pretty well, i went to one hill race. I was third with old Yamaha, it was funny. I was beaten by 1100cc turbo arcticcat and 850 skidoo or lynx, can't remember.
    Jetting is little bit lean so i have to check it before winter.
    Always have to do something new for every season, so i bought a box full sh*t... Ofc everything is broken or modded...
    Some pictures:Bigbore_motor.jpg Notice those cylinders, two 73mm and one in the middle is 74mm... and steel plated...
    hauck73broken.jpg Here is reason why someone changed that cylinder
    shit.jpg 74mm stick cut
    ruined.jpg Something what i have to do new, can't save those anymore, can anyone guess who made them originally?
    blasted parts.jpg But let's start with the easiest parts
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  7. #17
    Join Date
    Jan 2009
    Posts
    5,545
    Default
    What the hoot is that in the fourth picture? The one after the shot of the piston.
    Dannyboy
  8. #18
    Default
    Those should be silencers, but it is hard to even regonice. I will do new silencers when i have time. I have done little airbox mod for 38mm carbs, will post pics later.
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  9. #19
    Senior Member ProStock Vincent's Avatar
    Join Date
    Aug 2015
    Ontario Canada
    Posts
    577
    Default
    Cool thread
  10. #20
    Default
    It it hard to find time to build, sled locates 300km away so i don't have time on a week to build it.
    But litte progress, modded airbox for tmx 38mm. I'm going to put silicone hose between carburetor and airbox.
    Started to make new silencers, let's see what can i do
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
Posting Permissions
  • You may not post replies
  • You may not edit your posts
