Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: Years with Yamaha SXViper
  1. #41
    Default
    Bought some Hauck Venom head, actually i wanted just water rail so i can fit it to 780 so i don't have to mod that what i made earlier. No motivation for dirty aluminiun welding��
    I think i could use that on my 700, mut dome size is 19cc. So i think it is way too stiff. There was some detonation or something on one chamber so i used lathe and i took littlebit off. I know it changes squis, but if i want to use those i think i need to get dome size something like 21cc...
    And i also broke my chaincase, because chain broke down... It was a fast fix, i have a sparepart in my garage so i just swapped all parts to another case. Also changed gearing 23/38, i think it is littlebit too long, when there is 20cm of pow it wont go over 150km/h, need to find hard packet rail to go faster.
    Allmost all pipes are now welded, need to sand them and paint. Maybe i need to weld some spring mounts, but let's see ��
    Also went to watch local snowcross race, i still wish that there could be some triples racing, that sound is just so amazing.
    Yamaha SXViper 2002
    2" riser
    44" stance
    Blue headlight cover
    DIY windshield
    18.9" fox floats on front end and 18.7" fox float on rear skid
    Tunnel stiffeners and protective tube
  2. #42
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,665
    Default
    Quote Originally Posted by sx viper View Post
    I take it that you have a redhead.
    Dannyboy
  3. #43
    Default
    Quote Originally Posted by A couple of bucks View Post
    Stock Viper 700 engine, or what do you mean? That head is with six bolts per cyl, not five like redheads?
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  4. #44
    Join Date
    Jan 2009
    Posts
    5,665
    Default
    Venom as in .... Viper body w/ a redhead? Or did Hauck call them Venom?
    Dannyboy
  5. #45
    Default
    I think Hauck just call them Venom heads. Totally different meaning than SXVenom
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  6. #46
    Join Date
    Jan 2009
    Posts
    5,665
    Default
    I got cha. I did not know there were Viper heads out there w/ the Venom name.
    Dannyboy
  7. #47
    Default
    Old folks get confused sometimes....
    I would know! Lol
    1997 Yamaha XTC 600
    700 Redhead, Mr. Viper ported, CPR pipes, 20CC Domes, boost bottle, SRX reeds, Heelclickers, Dual bulb, LT Ohlins
    1997 700 SX
    Thinned head gasket, Gutted Airbox, Reed Spacers, Bender Pipes, Viper Shocks, 51/43 helix 89L weights
    2004 Viper S
    SLP pipes, peak performance head,
    2001 SRX 700
    Stock?
    1997 Mountain Max 700
    Black XTC Hood, Thinned Head Gasket, Gutted Air Box, Reed Stopper Notch, SLP Pipes
Posting Permissions
  • You may not post replies
  • You may not edit your posts
