Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: Years with Yamaha SXViper
  1. #51
    Default
    One pic of broken clutch, still looking for heel clicker weights!
    I have some nice ski fixing project, actually it is plastic welding, i post pictures later.
    Yamaha SXViper 2002
    2" riser
    44" stance
    Blue headlight cover
    DIY windshield
    18.9" fox floats on front end and 18.7" fox float on rear skid
    Tunnel stiffeners and protective tube
  2. #52
    Default
    Here is some pictures of ski fixing project.
    Starting point, first i grind all surfaces with grinder. Need to get those clean.
    Then i added some PE plastic pieces and weld them all around, because i need to create a shape for ski and grind a lot of material off.
    Plastic welding is very accurate job, you need to check temperatures all the time. If that plastic "oil" comes to top of material, then it is ruined.
    After plastic welding i drilled new holes for driver iron and then i grind skiis bottom so they look like a original.
    Because skis were from skidoo or actually mountings were from skidoo so i need to make 10mm plastic spacer under rubber. I also put some screws to keep it together.
    Yamahas ski pivot is littlebit wider so i grinded 1mm on each side to make it fit properly.
    Finished product.
    Some youtube link of Blade skis, those are DS model so it is littlebit different.
    Throw some comments what you think and also offer me some heel clicker weights
    Or do i have to 3d scan those weight pieces what i have and send models to some engineering works so they can make it?
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  3. #53
    Default
    Wow, that's impressive. I would have thought from those original pics that they would be unusable!
  4. #54
    Default
    Why don’t you just call the company and order a new set of heel clickers?
    1997 Yamaha XTC
    700 Redhead, Mr. Viper ported, CPR pipes, 20CC Domes, boost bottle, SRX reeds, Heelclickers, Dual bulb, LT Ohlins
    1997 700 SX
    Thinned head gasket, Gutted Airbox, Reed Spacers, Bender Pipes, Viper Shocks, 51/43 helix 89L weights
    2004 Viper S
    SLP pipes, peak performance head,
    2001 SRX 700
    Power Inc. Pipes
    1997 Mountain Max 700
    Black XTC Hood, Thinned Head Gasket, Gutted Air Box, Reed Stopper Notch, SLP Pipes
  5. #55
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,817
    Default
    I have some 2-speed H/Cs if your interested.
    Dannyboy
  6. #56
    Default
    Quote Originally Posted by MURDER YAMAHA View Post
    I haven't never phoned on us companys, it is also pretty expensive. If i bought some new it will cost so many $$$ because i have to pay shipping fees and taxes + VAT of whole price so that is why i don't like that option. I would like to get some used for little cheaper.
    "A couple of bucks" i send you a private message.
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  7. #57
    Join Date
    Jan 2009
    Posts
    5,817
    Default
    I'll get you a picture of them.
    Dannyboy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
