Results 1 to 4 of 4
Thread: Exciter jugs
  1. #1
    Junior Member Mini
    Join Date
    Feb 2018
    Canada
    Posts
    12
    Default Exciter jugs
    Hi , I currently have a 93 sx. Question is can I use jugs from different models ? Same year? Like the ex model? They are way easier to find and alot cheaper to acquire.
  2. #2
    Senior Member Stock vmax-540's Avatar
    Join Date
    Oct 2006
    Ogdensburg New York
    Posts
    150
    Default
    Any of the other year 570 cylinders will work, but the SX porting is different then any year Exciter. So yes you can but I would stick with the later years that are Nikisil lined, and either just bolt them on or grind the ports to match the SX's. Obviously if you just bolt them on performance will be affected.
    1983 Vmax 540
    1981 SRX 440
  3. #3
    Senior Member Open Mod
    Join Date
    Jun 2007
    Burlington Wi.
    Posts
    1,055
    Default
    More than just porting is different on the SX. Intake runners on cylinders are shorter. Will be tough to fit the carbs. Head and gasket are also different. Can be done but more to it than it looks on the surface.
    opsled
    I reserve the right to change my mind if someone can prove to me it needs replacing.
  4. #4
    Senior Member Open Mod shaggyzr2's Avatar
    Join Date
    Dec 2011
    Central Wisconsin
    Posts
    1,880
    Default
    If you can't find SX cylinders have yours replated.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
