Results 1 to 8 of 8
Thread: Venom 600 clutch kit?
  1. #1
    Default Venom 600 clutch kit?
    Can anyone recommend a good trail clutch kit, looking for stronger pull on low to midrange, anyone have a good setup they can share. Thanks
  2. #2
    Default
    This is a set-up I found on the technical pages of this site, there are quite a few other ones on there as well but to be honest I have never put a clutch set-up on a 600 yet so I have no experience on how any of them work.
    99 SX600 Trail
    51/43 Helix, 8-ca weights 0.8g in tip, 2-3 engagement shims, stock spring primary, silver secondary, 1 or 2 layers removed from head gasket and 20/40 gearing. Jetting: 140 mains
    2000 vmax 700
  3. #3
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    2,916
    Default
    with the crappyness of modern gas, only remove one head gasket layer max unless you are positive you are getting 91+ octane to prevent a burndown.
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  4. #4
    Senior Member ProStock Vincent's Avatar
    Join Date
    Aug 2015
    Ontario Canada
    Posts
    506
    Default
    Quote Originally Posted by Maim View Post
    100% Agree! Only remove the middle layer of the head gaskets.
    Thining the headgaskets and doing the notchs in the reed stoppers, really help wake up these motors. Make sure your reed stoppers are stainless ones.
  5. #5
    Default
    i thought the reed notches were for the 500 engines? would spacers be better or about the same?
    thanks guys
    2001 SRX 700 Mine
    8DN 20's
    4.5 mid
    5.5 tip
    secondary green at 70
    Dalton 56/44
    2004 Yamaha Venom Wife's new sled
    2003 120 ZR Sons
    Studded.
    Sons New Ride
    2012 Phazer RTX.
  6. #6
    Join Date
    Aug 2015
    Ontario Canada
    Posts
    506
    Default
    Quote Originally Posted by RB2001SRX700 View Post
    thanks guys
    The notches work for the 500, 600 twins, and 600, 700 triples. I agree with you, I would think the spacers would be a bit better. I've only tried the notches on my 700 so I have nothing to compare it to.
  7. #7
    Senior Member Open Mod shaggyzr2's Avatar
    Join Date
    Dec 2011
    Central Wisconsin
    Posts
    1,814
    Default
    Quote Originally Posted by nails View Post
    99 SX600 Trail
    That set up probably wouldn't work the same for the venom, the venom is long travel and the sx is short travel, the engine stuff would be the same but clutching and gearing would be different.
  8. #8
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    2,916
    0 out of 1 members found this post helpful.
    Default
    that clutching should work. gearing is only out 1 tooth compared to stock as stock is 20/39.
    sleds
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
Posting Permissions
  • You may not post replies
  • You may not edit your posts
