Results 1 to 4 of 4
Thread: no main shaft grease?
  1. #1
    Member Mini
    Join Date
    Apr 2016
    Denver, Colorado
    Posts
    31
    Default no main shaft grease?
    a buddy's artic cat just grenaded on him
    he wasn't aware he had to lube the bottom bearing
    the mountain max doesnt have a greaseable lower correct?
    love these old sleds!
  2. #2
    Super Moderator super1c's Avatar
    Join Date
    Sep 2003
    Freeland & Otsego lake, MI
    Posts
    4,823
    Default
    It doesn’t have a grease fitting but should be greased every year. Take off secondary and with a small pick you can remove bearing seal. Use a needle greaser to shoot new grease in and force old out. Just be careful with seal. I do both drive and jackshaft bearing every year. Original bearings still look new.
    2002 Yamaha SXViper - Daughters
    E-start, reverse, extended to 144" with cobra track. Awesome EdgeWrap in purple and pink!!
    04 Yamaha SXViper S - Extra
    E -Start, reverse, Ohlins all the way around, Extended to 144", cobra track! Cant get rid of this sled just yet!!
    2016 Yamaha SRViper LTX-SE - Wifes.
    2017 Yamaha SRViper LTX-LE - Mine
    THE VIPER PIT IS NEVER COMPLETE! Bipolar!!!
  3. #3
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    2,905
    Default
    i do this every season to my sleds and my apex just finally had that bearing fail at roughly 11000 miles (18000 km). if it has the rubber seals, yes you can pick them out and repack them with grease. some of the replacement ones have steel seals on them i i reccomend changeing them every 2-3 season to prevent failure. the steel ones can be re-packed but it is a pain to do them.
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  4. #4
    Member Mini
    Join Date
    Apr 2016
    Denver, Colorado
    Posts
    31
    Default
    excellent!
    thanks guys
Posting Permissions
  • You may not post replies
  • You may not edit your posts
