Results 1 to 3 of 3
Thread: 2004 venom fuel pump ?
  1. #1
    Senior Member Stock
    Join Date
    Jan 2004
    m.n.
    Posts
    100
    Default 2004 venom fuel pump ?
    Hi, does anyone know if the fuel pump on a venom,has a built in fuel shutoff, my sled sits around for a week or two and the crankcase is loaded with gas, pulled off vacum line from pump and no fuel on that side of pump,which is good, could it be a tank venting issue or a bad fuel pump.
  2. #2
    Super Moderator super1c's Avatar
    Join Date
    Sep 2003
    Freeland & Otsego lake, MI
    Posts
    4,854
    1 out of 1 members found this post helpful.
    Default
    Sounds like a stuck check valve in fuel pump. Not sure about venom but you could clean the old red head fuel pumps.
    2002 Yamaha SXViper - Daughters
    E-start, reverse, extended to 144" with cobra track. Awesome EdgeWrap in purple and pink!!
    04 Yamaha SXViper S - Extra
    E -Start, reverse, Ohlins all the way around, Extended to 144", cobra track! Cant get rid of this sled just yet!!
    2016 Yamaha SRViper LTX-SE - Wifes.
    2017 Yamaha SRViper LTX-LE - Mine
    THE VIPER PIT IS NEVER COMPLETE! Bipolar!!!
  3. #3
    VIP Lifetime Member
    Join Date
    Jan 2009
    Michigan
    Posts
    541
    Default
    If the tank vent is plugged, it could push gas through the carbs if the pressure rises in the tank enough, especially if the carb needle & seat sealing has become weak. Which then leads in to:
    If your O-ring on the carb needle seat hasn't been replaced recently, they tend to stiffen up and not seal so well over time. Also check the tip of the needle and its' corresponding sealing surface inside the seat to make sure they are smooth and not damaged. In either case, fuel can flow through the carb and into the engine case, whether the tank vent is plugged or not.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
