Results 1 to 4 of 4
Thread: Viper 2 1/2 lug
  1. #1
    Default Viper 2 1/2 lug
    How do I get the clearance at the drivers for a 2 1/2 track. The 7 tooth 2.86 is the same diameter as the 8 tooth 2.52.
  2. #2
    Super Moderator super1c's Avatar
    Join Date
    Sep 2003
    Freeland & Otsego lake, MI
    Posts
    4,978
    Default
    That’s a lot of lug for the proactions. Drop and roll the chain case my be your only option, but can get pricey to find someone to do it!
    2002 Yamaha SXViper - Daughters
    E-start, reverse, extended to 144" with cobra track. Awesome EdgeWrap in purple and pink!!
    2016 Yamaha SRViper LTX-SE - Wifes.
    2017 Yamaha SRViper LTX-LE - Mine
    THE VIPER PIT IS NEVER COMPLETE! Bipolar!!!
  3. #3
    VIP Lfietime Member
    Join Date
    Dec 2010
    Hardin, MT
    Posts
    266
    Default
    I looked into doing that at one point, 7 tooth 2.52 should leave enough clearance but not by terribly far and thats a pretty tight bend. I ended up doing an ekholm tunnel drop and roll. Used parts are the only affordable way to go, if you can find them. There was 3 sleds for sale around here that had those parts this spring.
  4. #4
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,665
    Default
    You WILL have tunnel/snow evacuation issues w/ a 7 tooth,2.52 and a 2.5 lug. Drop and roll it.
    Dannyboy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
