Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: One sledders trash is another ones trouble
  1. #21
    Senior Member Stock
    Join Date
    Nov 2011
    Yellowknife, NWT
    Posts
    192
    1 out of 1 members found this post helpful.
    Default
    Thanks Main. Just by luck I found one yesterday along with the steering arms. Picking them up today so I should be in good shape to finish the front end.
    1977 Yamaha SRX (Mod Stock Drag)
    1979 Yamaha SRX
    1979 Skidoo Blizzard Cross Country
    1981 Yamaha SRX
    1981 Yamaha SS440
    1981 Kawasaki Invader LTD 4/6
    1981 John Deere Spitfire
    1982 Yamaha SRV
    1989 ET400TRN
    1991 Yamaha Phazer ST
    1992 Yamaha Venture TF
  2. #22
    Senior Member Stock
    Join Date
    Nov 2011
    Yellowknife, NWT
    Posts
    192
    Default
    Some of the trouble:
    IMG_20180827_173122.jpg Seized piston needed a little persuasion.
    IMG_20180901_231751.jpg Con rod bearing has seen better days. Explains that knocking sound.
    IMG_20180901_135047.jpg Crank and rods are good. Just need new bearings and thrust washers.
    IMG_20180901_135047.jpg Never trued a crank before but I guess I'm gonna have to learn.
    IMG_20180829_203116.jpg Airbox needed gutting for the Vmax 600 carbs to be of any use.
    IMG_20180913_215934.jpg Lot's if paint stripping
    IMG_20180915_171028.jpg Cans are done and 1-1/4" track is in. Need to decide whether to shorten the sway bar or lengthen the torque arms to work with the longer steering arms and struts.
    1979 Yamaha SRX
    1981 Yamaha SRX
    1981 Yamaha SS440
    1982 Yamaha SRV
    1989 ET400TRN
  3. #23
    Junior Member Mini
    Join Date
    May 2017
    BC Canada
    Posts
    4
    Default
    subscribed!
  4. #24
    Senior Member ProStock Vincent's Avatar
    Join Date
    Aug 2015
    Ontario Canada
    Posts
    640
    Default
    Nice build
  5. #25
    Senior Member Stock
    Join Date
    Nov 2011
    Yellowknife, NWT
    Posts
    192
    Default
    Question for anyone who has done the flatslide carb conversion. Did you leave the lower baffle tube in place when you gutted the airbox or does it need to be removed or modified as well? Any advice would be appreciated.
    1979 Yamaha SRX
    1981 Yamaha SRX
    1981 Yamaha SS440
    1982 Yamaha SRV
    1989 ET400TRN
  6. #26
    Senior Member Stock
    Join Date
    Nov 2011
    Yellowknife, NWT
    Posts
    192
    1979 Yamaha SRX
    1981 Yamaha SRX
    1981 Yamaha SS440
    1982 Yamaha SRV
    1989 ET400TRN
  7. #27
    Senior Member Stock
    Join Date
    Nov 2011
    Yellowknife, NWT
    Posts
    192
    Default
    Wanted to keep the rear of the sled looking as original Phazerish as possible with the 136" extension. Decided to try infilling with some additional grips for the powder.IMG_20190115_222016.jpg
    1979 Yamaha SRX
    1981 Yamaha SRX
    1981 Yamaha SS440
    1982 Yamaha SRV
    1989 ET400TRN
  8. #28
    Senior Member Stock
    Join Date
    Nov 2011
    Yellowknife, NWT
    Posts
    192
    Default
    No need for an aftermarket tunnel extension. Just need to customize a short piece of tunnel and stock reinforcing brackets from a parts sled and she's done.IMG_20190115_223334.jpg
    1979 Yamaha SRX
    1981 Yamaha SRX
    1981 Yamaha SS440
    1982 Yamaha SRV
    1989 ET400TRN
Posting Permissions
  • You may not post replies
  • You may not edit your posts
