Results 1 to 2 of 2
Thread: Headlight swap
  1. #1
    LIFE MEMBER ONLY ONCE!!! bluemonster1's Avatar
    Join Date
    Dec 2005
    Howden ,Manitoba,Canada
    Posts
    12,761
    Default Headlight swap
    Is it possible to switch from a single bulb headlight from a 97 Sx 700 to a dual bulb headlight from a 2002 SRX 700. I would think that wattage is the problem,but can it be done.
    <---- my fingers do the talking..can't stop...voices in my head tell me to type.... ..out of my way...more info...need more!!!
    SRX SRX SRX SXR SXR
  2. #2
    Default
    Yes, I have done it, you need the headlight, also if you don’t want to change the stator, just use two 35watt bulbs, or a couple LED bulbs. You will also need the dual bulb gauge pod, and windshield
    Only other consideration would be the wiring harness. I just soldered in an extra headlight plug to the original.
    1997 700 SX
Posting Permissions
  • You may not post replies
  • You may not edit your posts
