Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Track for Venture
  1. #1
    Senior Member ProStock Millinocket Rocket's Avatar
    Join Date
    Mar 2005
    Sebago Lake, Maine
    Posts
    727
    Default Track for Venture
    Just bought an 01 Venture in great shape but it definitely needs a track upgrade. Can anyone tell me which track will work on this sled, max lug height? I'm hoping to find something used, so will a 136" from another brand sled work as well? Thanks
  2. #2
    Senior Member ProStock Vincent's Avatar
    Join Date
    Aug 2015
    Ontario Canada
    Posts
    723
    Default
    The max is about 1.5" lug height. That's with no forward heat exchange protectors. I run 1.35 Cobra for the last 4 season on my 700 Venture witch is an excellent on /off trail track .
    My brother ran a 1.25" ripsaw (first Gen) on his 600 venture. Great on trail track not so good off trail but you often find them used and for sale.
    Shouldn't have problems finding a used 136" (2.52 pitch). They are very commun tracks and we're used on many, brands, makes and models.
  3. #3
    Join Date
    Mar 2005
    Sebago Lake, Maine
    Posts
    727
    Default
    Thanks Vincent, that's the exact track I was hoping to be able to use height-wise. Do those come studded or do they need to be picked?
  4. #4
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,273
    Default
    put a 1-1/4" ripsaw on my dads 05 sx venture. we love it on that sled. as his gets used by guest riders that do not know warning sounds of eaten exchangers, i would only run a ice ripper or pre moulded stud track to prevent the loss of an engine from punctured cooler.
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  5. #5
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,825
    1 out of 1 members found this post helpful.
    Default
    Quote Originally Posted by Millinocket Rocket View Post
    As long as it is a 2.52 pitch. My sons SX6 has a Cat quiet track.
    Dannyboy
  6. #6
    Senior Member Improved low slung's Avatar
    Join Date
    Feb 2005
    Newfoundland
    Posts
    466
    Default
    136inch polaris tracks with the 2.52 pitch are a consideration..
  7. #7
    Join Date
    Mar 2005
    Sebago Lake, Maine
    Posts
    727
    Default
    Great, thanks for the info guys.... I'm hoping a 1-1/4" with picks will fit... and leaving the front heat exchanger protectors in?
  8. #8
    Join Date
    Jan 2009
    Posts
    5,825
    Default
    If you are not out to stomp the competition into oblivion, I strongly advice you not to pick. Get something that has built-ins and never worry about throwing a pick through the heat exchanger ever again. And then consequently burning it to the ground. After all ..... this is 2-up Venture.
    Last edited by A couple of bucks; 10-12-2018 at 04:57 PM. Reason: Improper sentence
    Dannyboy
  9. #9
    Join Date
    Jan 2009
    Posts
    5,825
    Default
    With my sons SX6 , the Cat quiet track was basically a Ripsaw Gen I 1.25". And we still needed to remove the front protectors.
    Dannyboy
  10. #10
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,273
    Default
    i do not often drive my dads and unless you are going to drive it personally, i would use an ice attack or put in the i grip studs like mrsled did last season on his apex and sidewinder.
    sleds
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
Posting Permissions
  • You may not post replies
  • You may not edit your posts
