Results 1 to 8 of 8
Thread: Changing Throttle Cable, Access to Oil Pump End?
  1. #1
    Default Changing Throttle Cable, Access to Oil Pump End?
    Putting a new throttle cable on the 04 Viper S. How do I get to the end on the oil pump, looks pretty buried.
  2. #2
    Super Moderator super1c's Avatar
    Join Date
    Sep 2003
    Freeland & Otsego lake, MI
    Posts
    5,041
    Default
    You have to take the rear mag side motor mount off to get at it. The motor mount comes out easy then oil pump right there.
    2002 Yamaha SXViper - Daughters
    E-start, reverse, extended to 144" with cobra track. Awesome EdgeWrap in purple and pink!!
    2016 Yamaha SRViper LTX-SE - Wifes.
    2017 Yamaha SRViper LTX-LE - Mine
    THE VIPER PIT IS NEVER COMPLETE! Bipolar!!!
  3. #3
    Default
    What needs to come off prior to the mount?
  4. #4
    Join Date
    Sep 2003
    Posts
    5,041
    Default
    Quote Originally Posted by duwem View Post
    Airbox, carbs for sure. I donít remember but I donít think you have to take mag side reed cage out.
  5. #5
    Join Date
    Sep 2003
    Posts
    5,041
    Default
    And that was mag side rear motor mount. Fixed in previous post
  6. #6
    Default
    Should I just adjust to match what's on there for the pump and carbs or is there a procedure?
  7. #7
    Join Date
    Sep 2003
    Posts
    5,041
    Default
    Should be no adjustment needed on carb other then 2mm gap at throttle before carb slide moves. I always go a hair more to make sure torrs doesnít kick in. Oil pump cable should have 21 +/- 2mm gap when cable is fully pulled out at adjuster.
    Attached Images Attached Images
  8. #8
    Default
    Thanks!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
