Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Et300 no spark
  1. #11
    Default
    Great idea. I was thinking they would just rust over quickly after sanding but wasn't sure if a coating would screw it up. BTW , sanding those parts down did not work. I think I found a stator for it.
  2. #12
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,594
    Default
    I've dusted them lightly w/ paint too. Heat seems to "loosen" the adheared paint over time. I prefer the ultra thin battery terminal protector. Warm up the metal before spraying it down.
    Dannyboy
  3. #13
    Default
    I figure I should do the mag crank seal while I have the stator out. Is installing it the same deal as a crank or cam seal on a car? I did them on my Chevy metro which is basically a snowmobile engine. Or should I just leave it alone. I don't want to open up another can of worms. Any tips on installing/removing the seal?
  4. #14
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,150
    Default
    last ones i got into i had to split the bottom end witch was a good thing as one of the crank bearings was bad on the 78 et340 i did.
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  5. #15
    Join Date
    Jun 2007
    Burlington Wi.
    Posts
    1,057
    Default
    Engine must come out and cases split to do crank seals.
    opsled
    I reserve the right to change my mind if someone can prove to me it needs replacing.
  6. #16
    Default
    So I got a 'new' used stator but when I installed the flywheel I could here it grinding on the new stator. I pulled the flywheel back off and it definitely is grinding. Where do I go from here?
  7. #17
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,150
    Default
    is it the same size as the one you took out? i have seen the pick up coil adjusted out too far on a few out boards, when they are adjustable.
    sleds
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  8. #18
    Default
    It looks identical. I'm thinking maybe a chunk of dirt or rust may have got in there. I'll retry tomorrow.
  9. #19
    Default
    Cleaned everything real good and it fired up. Must have been a chunk of rust or dirt.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
