Results 1 to 3 of 3
Thread: drilling holes in hy fax (slides)
  1. #1
    Junior Member Mini
    Join Date
    Dec 2015
    Orono, Ontario
    Posts
    26
    Default drilling holes in hy fax (slides)
    Looking through the tech articles there is a reference to drilling a pattern of holes in the slides to trap and hold snow. This is supposed to increase slide longevity. I am looking for anyone who has personal experience doing this and if they felt it was a worthwhile effort?
  2. #2
    VIP Lifetime Member fourbarrel's Avatar
    Join Date
    May 2003
    Posts
    2,647
    Default
    I've done it in the past,not from any particular pattern just went at the hyfax.The trick I found was to drill your holes angled slightly so that the snow is rammed into the holes from the front of the skid area.I've seen guys drill the holes straight up into the hyfax and I'm sure that will work too but if you angle your holes forward it will keep them full of snow better IMO.As far as size of the holes if I remember right I used a 3/16" drill bit but 1/4 " seems to be the average size used,just don't drill through your sliders too far,you just want the holes big enough and deep enough to hold snow so that it will melt out once the temps of the sliders gets hot enough.Personally I think it helps to prolong the life of the hyfax.
    I'll be right home honest.
    Looks like the couch again tonight.
    If I have to explain it you wont understand.
    SLED MODS:
    98 SRX 700
    reverse
    heelclickers w/dalton 50/39 helix
    Cobra w/s
    Apex skid
    Rox riser
    Powermadd handguards
    extended brake hose
    Pilot x skis
    2000 electronics
    Boss seat
    2001 SRX 700
    Bender trail ported
    Boyesen Rage Cages
    8DN20s w/54-46 Dalton
    21/38 gearing
  3. #3
    Senior Member Open Mod norwegian's Avatar
    Join Date
    Nov 2004
    norway
    Posts
    2,446
    Default
    Dupont slides are worth the cost, so if you have the skid off the sled anyways, so just go for them then.
    See the whole waterskipping at http://www.elgen.net/veivisr/srx-shooting2.wmv
    Stating the obvious is not neccesary!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
