Results 1 to 3 of 3
Thread: 1997 VT 500. The hose from the coolant bottle goes where?
  1. #1
    Senior Member Open Mod norwegian's Avatar
    Join Date
    Nov 2004
    norway
    Posts
    2,408
    Default 1997 VT 500. The hose from the coolant bottle goes where?
    I had the lower crankcase changed on the vt 500. Where does the hose from the coolant bottle go to? It is lose now and the sled is losing coolant. If I try to refill, the blue (which I fill in) will drain right above the heat exchangers.
    See the whole waterskipping at http://www.elgen.net/veivisr/srx-shooting2.wmv
    Stating the obvious is not neccesary!
  2. #2
    Default
    It connects just under the radiator cap.
    1997 Yamaha XTC 600
    700 Redhead, Mr. Viper ported, CPR pipes, 20CC Domes, boost bottle, SRX reeds, Heelclickers, Dual bulb, LT Ohlins
    1997 700 SX
    Thinned head gasket, Gutted Airbox, Reed Spacers, Bender Pipes, Viper Shocks, 51/43 helix 89L weights
    2004 Viper S
    SLP pipes, peak performance head,
    2001 SRX 700
    Stock?
    1997 Mountain Max 700
    Black XTC Hood, Thinned Head Gasket, Gutted Air Box, Reed Stopper Notch, SLP Pipes
  3. #3
    Join Date
    Nov 2004
    norway
    Posts
    2,408
    Default
Posting Permissions
  • You may not post replies
  • You may not edit your posts
