Main Jet Ring Orientation
Yzed608
WI
For my 2004 Venom, the manual shows the main jet ring as the white plastic type. The carbs actually have a smaller brass piece. I am unsure of what the correct orientation should be. Ever since I bought the sled the ring has been in the orientation shown where the main jet is slightly raised (first photo). I tried putting it the other way and can see how it would work. What is correct? I've never had a problem that I've noticed so far, but I'd rather have it how it was intended. I could see how it would make more sense with the jet down inside the ring, as the pilot is that way.
How the ring has been oriented:
Flipped other way:
Ok, thanks guys. I'll leave it as is.
attachment.php
Ok, this makes more sense now. The manual doesn't show the brass ring there, just the white plastic ring. I was thinking the brass ring replaced the white one at some point and the manual wasn't updated, but seeing other photos it did not. I'm just missing the white plastic rings. Photo from tech page:
Thanks for the help. I can see how this post would make no sense if you knew the correct orientation :oops:.
