V-max 1994 secondary clutch
skorped-t5
Skorped SWEDEN
Website
www.garaget.org
Hi. I have for a long time read that a newer secondary clutch ,fitt vmax 500 1994.
What year should i look for,to put on my sleed? Is there some more parts i need to change ,when putting on a newer clutch?
/ Tomas
95/96 Vmax-500/600 is what you want for your 94. Also fits Phazer, SRX and 540 Vamx.
Pic is of 95 Vmax 600 setup on 87 540 Vmax.
Do i need something more than the secundary clutch? Like driveshaft or somehing from gearbox?
No, Not if you use the 95/96 Vmax secondary. You will need a longer retaining bolt and spacer. Either go to hardware store for a longer bolt and make the spacer (easy) or buy new/used from 96-99 Phazer.
Use any other Yamaha secondary of this type and you will have to modify spline depth and offset as Maim is showing with that link.
95/96 Vmax 5/600 secondary is correct for your 94.
opsled
