tach ?
Lester
Bootlake Mi
I have a 2000 srx 700,sled has 5200 miles on it.The tach started fluttering,if you hold it a specific rpm it will flutter sometimes.,it will do it at idle also.any ideas of what is causing this ?
Check your wiring harness for a rub through. Usually it happens with the harness that runs under the motor and goes to the hood.
No need to pull motor like stated above. Tie a string to the harness so you can pull it back under.
