Emergency Brake
s10mike
holland michigan
Is the E-brake cable from a Mountain Max longer than a sxr-srx-vmax brake cable? I need to figure out a better set-up after installing a bar riser.
Cables are all xxx-26351-xx-xx.
The mountain max is a 8ED, same as a SXR, so don't think its longer.
If I recall correctly, I think some people were using a 2006 Mountain Viper cable ?
May be incorrect...
Anyway, that's a 8EN-26351-00-00.
Handlebars and steering column are different that a regular Viper, so Im thinking higher.
That would then need a longer cable.
