Results 1 to 6 of 6
Thread: Drive bearing sethe screws
  1. #1
    Senior Member ProStock
    Join Date
    Feb 2004
    Channaho, Il.
    Posts
    569
    Default Drive bearing sethe screws
    I am looking for the diameter and thread pitch for the set screws on the drive shaft bearing. I know they are sold separately from the bearing. I just need the size.
  2. #2
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,920
    Default
    What p/n are we referring to?
    If you have the bearing, run down to the nearest ACE with it. Our ACE has an entire isle on both sides w/ those pull out trays. Imperial & metric sizes.
    Dannyboy
  3. #3
    Join Date
    Feb 2004
    Channaho, Il.
    Posts
    569
    Default
    Unfortunately the set screw is a very odd size. Its a 6mmx.75. Ace does not have that size. I found a tap in our tool room that fit
  4. #4
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,337
    Default
    any old sleds around you can steal them from? i always keep a few from all the ones i have replaced over the years. they are the same bearing in all the sx/rx/rx/apex/vector sleds. i keep a sapre newq one in the tool box in the trailer.
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  5. #5
    Join Date
    Feb 2004
    Channaho, Il.
    Posts
    569
    Default
    Fastenal has them for $1.35. Part number Fastenal Part No. (SKU) 11506480
  6. #6
    Join Date
    Jan 2009
    Posts
    5,920
    Default
    That same bearing is used a lot in agriculture. I found that out while down at the CASE IH store. They keep at least 25+ stocked at all times. Mostly the eccentric type. Remember to install w/ it so that it is locked in the direction of rotation.
    Dannyboy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
