2000 srx 700 stator testing
The following was C&P from a search.
Charging Coil Measured resistance between the black wire and white wire
0.36 Ohms +/- 10% @ 20*celcius (68*F)
Source Coil Resistance (should be a 3 wire plug with a Black/red, Brown and Brown/Red )
Resistance between Brown and Black/Red
392 - 479 Ohms @ 20* Celcius (68*F)
Resistance between Brown and Brown/Red
78 - 94 Ohms @ 20* Celcius (68*F)
Pickup Coil Resistance Measured Between White/Red and White/Green (2 wire plug)
189 - 231 Ohms @ 20* Celcius (68*F)
For 1997-2000
Hey , I know this is kinda late but here are spec form m 2000 srx 700 manual: Pick up Coil - White/Red to White/Green resistance 189-231 ohms @ 68f (20c). Charge coil resistance White to White 0.36 - 0.44 ohms @ 68f (20c)
