Results 1 to 8 of 8
Thread: White max performance primary spring.
  1. #1
    Junior Member Mini
    Join Date
    Jan 2014
    michigan
    Posts
    27
    Default White max performance primary spring.
    Sorry I meant to put this on the wanted forum.
  2. #2
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,390
    Default
    moved for you.
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  3. #3
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    6,027
    Default
    Do you know the rates for it?
    Dannyboy
  4. #4
    Senior Member Open Mod norwegian's Avatar
    Join Date
    Nov 2004
    norway
    Posts
    2,528
    Default
    Search up Paige Polyak (Not too sure whether the name refers to a male or a female, but the person on the picture is male). I bought a Purple Maxx perf spring for him, he is going to ship it on monday. Guess what he bought? The inventory of maxximum performance. BTW, the white is 60-2,28-130 kg
    2002 SRX 700. The 120++ mph sled. Gearing, Dalton helix, belly pan protector, MM skis, Maxx perf transfer rods, TPI valves, temp gauge and heelclickers
    2001 MM 700. Reedstopper notch, hauck headgasket, Heelclickers, Hauck Magnum roller, Dalton helix, transfer enhancement kit, temp gauge, bellypan protector.
    1999 VT 600. European edition. Cargo rack, cargo box, tow hitch, 50/36 Dalton helix.
    1997 VT 500.Tempaflow, dupont hyfax, belly pan protector, 39 deg helix, heeclickers, tow hitch.
  5. #5
    Default
    Hauck Orange is very close and will make you smile
  6. #6
    Junior Member Mini
    Join Date
    Jan 2014
    michigan
    Posts
    27
    Default
    Quote Originally Posted by Strokn4yamz View Post
    I actually have one of those, I'll try it with my 8bu set up from Yamiegod.��
  7. #7
    Junior Member Mini
    Join Date
    Jan 2014
    michigan
    Posts
    27
    Default
    Hello, I tried to find that member name but was unsuccessfu
    Any help would be appreciated.
    Thanks l
  8. #8
    Default
    Call Mike, he is the same guy.
    1-567-230-0221
    1997 Yamaha XTC
    700 Redhead, Mr. Viper ported, CPR pipes, SRX reeds, Heelclickers, Dual bulb, LT Ohlins
    1997 700 SX
    Thinned head gasket, Gutted Airbox, Reed Spacers, Bender Pipes, Viper Shocks, 51/43 helix 89L weights
    2004 Viper S
    SLP pipes, peak performance head,
    2001 SRX 700
    Power Inc. Pipes, Loaded 8DN20's, Hauck Y 51/45
    1997 Mountain Max 700
    Black XTC Hood, Thinned Head Gasket, Gutted Air Box, Reed Stopper Notch, SLP Pipes
Posting Permissions
  • You may not post replies
  • You may not edit your posts
