Results 1 to 6 of 6
Thread: Question for the body and paint guys
  1. #1
    VIP Lifetime Member fourbarrel's Avatar
    Join Date
    May 2003
    Posts
    2,665
    Default Question for the body and paint guys
    What the best way to fix a few knicks and gouges in a hood for an SRX before prepping to paint it? I had a window pane break against the side of the sled which made a few slight gouges in the side of the hood that will need to be fixed before it can be painted.Will regular plastic filler work or will the blemishes need to be fixed with plastic welding?
    I'll be right home honest.
    Looks like the couch again tonight.
    If I have to explain it you wont understand.
    SLED MODS:
    98 SRX 700
    reverse
    heelclickers w/dalton 50/39 helix
    Cobra w/s
    Apex skid
    Rox riser
    Powermadd handguards
    extended brake hose
    Pilot x skis
    2000 electronics
    Boss seat
    2001 SRX 700
    Bender trail ported
    Boyesen Rage Cages
    8DN20s w/54-46 Dalton
    21/38 gearing
  2. #2
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,885
    Default
    Wet sand and then apply spot putty w/ a spreader.
    Dannyboy
  3. #3
    Senior Member Open Mod bluewho's Avatar
    Join Date
    Oct 2003
    Caledon ontario
    Posts
    1,970
    Default
    Hard to say without pics but any reinforcement can be done on the inside of hood were you can build it up and not worry about how it looks or finishing it. I would take it to a body shop and get them to put a good spotputty on it or blow in some highbuild primer ,the money you give them would be better than using the crap spotputty that CT sells or the little bit you would use if you paid for a can of proper stuff.
    98 srx 700 doo sc10 3 ported.spi pistons.wide bars. wide frontend.1"preditor.160 golddiggers.
    98 srx 600 doo too
    2001srx700 doo sc10 3
    90 phazor
    90 exciter ported wide frontend adjustable shocks
    THEY SAY HE'S A MONSTER THIS BOY NAMED BLUE
    HE CAN RIDE LIKE A DEMON ON ONE SKI OR TWO
  4. #4
    Senior Member Open Mod shaggyzr2's Avatar
    Join Date
    Dec 2011
    Central Wisconsin
    Posts
    1,902
    Default
    If they're not too deep just use high build primer then wet sand
  5. #5
    Default
    From your explanation of how it happened I’d guess there not to deep. Da them down and feather edge the area. If still there then apply some poly filler/spot glaze “many terms for it” sand that out then 2k prime the area. Sand the very small imperfections out of the primer and begin the paint prep process. If pretty deep then sometimes I use a 2part autobody epoxy filler first. Don’t use rattle can products if you are going to use a good paint product on top. Many times it will go to crap fast. Also on the raw plastic areas many products call for plastic adhesion promoter first for best adhesion. This is a quick dos and don’ts to a kinda involved process for a professional refinish. If you are taking it to a shop to get painted I’d recommend talking to them first about prepping and repairing before they get to it. Also most products will come in sizes way bigger than you will need so it maybe worth just having them do it all if you are looking for a factory type finish.
  6. #6
    Join Date
    May 2003
    Posts
    2,665
    Default
    Thanks for all the advise guys,it pretty much went with what I thought I should do if I was to attempt this paint job myself. Rather than invest in a lot of equipment right now like a quality paint gun and a DA sander etc I just found a local body shop that can paint it for me.For $200 they will have it done in no time and I can look into ways to get into doing my own paint and body work later on.I hate being at the mercy of other people to do this kind of work for me and would rather be a bit more self sufficient so I can ge thtis kind of thing done at my time schedule.
    SLED MODS:
    98 SRX 700
    reverse
    Cobra w/s
    Apex skid
    Rox riser
    extended brake hose
    Pilot x skis
    2000 electronics
    Boss seat
    2001 SRX 700
    Bender trail ported
    Boyesen Rage Cages
    21/38 gearing
Posting Permissions
  • You may not post replies
  • You may not edit your posts
