Results 1 to 5 of 5
Thread: Exact Wheels on a 03 viper
  1. #1
    Junior Member Mini
    Join Date
    Nov 2017
    Philadelphia
    Posts
    10
    Default Exact Wheels on a 03 viper
    I'm pretty new at diving into doing maintenance on my 03 viper ER. I pulled the skid because I noticed the W arm was broken in a few places. I also need a few wheels. I can't seem to find the exact wheels that I need to replace them after a few nights of searching. Please help. This site is awesome. Ive already learned a lot by just reading all the info that everyone writes on here. Its what made me have the confidence to pull the skid on my own. Any help would be appreciated. Im gonna attach a picture with the wheels that I need to replace. Thanks everyone!
    Attached Images Attached Images
  2. #2
    Junior Member Mini
    Join Date
    Nov 2017
    Philadelphia
    Posts
    10
    Default
    Anyone?
  3. #3
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,337
    Default
    the lower front ones you have circled are what is called a marginal snow wheel kit. they usually need the bearings replaced/repacked every 2-3000 miles. kimpex makes a replacement wheel for those and it is used on the et410 as well as the phazer II to hold the track in the top of the tunnel. they are the same wheels as the ones on the shaft above them in pic. they do not make them in aluminum any more witch sucks as i found the bearings to last better in them.
    the rear uppers are usually replace with one with a changeable bearing as the oe ones where not. i do not remeber the part # for the one with the replaceable bearing and my parts book does not have it listed easliy. measure the diameter of the wheel and get the bearing part # to get your new wheels if needed. from what i am seeing they might just need a bearing re pack if they are not rusty when you pick a seal out.
    sleds
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of yamaha excellence (apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  4. #4
    VIP Member ProStock motorhead327's Avatar
    Join Date
    Oct 2010
    Northeast Ohio
    Posts
    543
    Default
    I think the small wheels up front are part# SMA-8H8PL-WH-00 and the carrier wheels are part# 8EK-47550-30-00
  5. #5
    Junior Member Mini
    Join Date
    Nov 2017
    Philadelphia
    Posts
    10
    Default
    Thanks everyone for the help!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
