129 Swap
MURDER YAMAHA
VIP Life Member
Minot ND
Has anyone ever swapped a 129 from a SR Viper into a proaction sled ?
Love the look of the rails on the newer sleds, and Im guessing the ride would be better as well.
Anyone have any insight on this ?
Looks like the front slides in instead of bolting up like ours.
Should work, you just need the hole locations from the donor sled off the tunnel from the drivers.
Yep, exactly. Was wondering the same thing till I looked up the parts diagram.
There is just a shaft that runs wall to wall inside the tunnel. I'm sure it makes install a bit easier.
