So the tunnel says 09/97 but think someone rooked me.
Mortagleus
Canada
Supposed to be a 1998/99 srx. Ownership is out with wife , i bought a chassis all blue all srx, installed motor , coolant lines and then electrical. Noticed 4 prong plug in a wierd spot beside orange coil wire. Fi ally figured it was for the power valves. BUT WHEN I TRIED TO BOLT POWER VALVE THERE WERE NO BOLT HOLES LIKE ON MY 99. So im frustrated did the 1998 have their power valve ypvs located in a different position?
I'm not positive on the year but the servo motor was relocated to the frame (clutch side) in order to allow removal of the airbox without having to remove the PV's and cables. Perhaps someone with a first year ('98) could chime in or post a pic?
It is a 1998 model because it's made the year before. The servomotor is located at the airbox, by the carbs.
