Results 1 to 8 of 8
Thread: Can I put a battery in a 03 sx viper non electric start model
  1. #1
    Default Can I put a battery in a 03 sx viper non electric start model
    Does anyone know if I can put a battery in my non electric start 03 sx viper without alot of grief? I just want it to run some accessories like heated shield and led powermadd hand gaurds, I dont want to cause excessive strain on my stator with these and figured if I knew what wire I could tie into to charge battery than problem solved. Thanks for your help, Dave
  2. #2
    Site Admin/CEO MrSled's Avatar
    Join Date
    Apr 2003
    Weston WI
    Posts
    9,139
    Blog Entries
    3
    Default
    You cant just tap a wire from the stator, there is more to it then that.
    Castle X Gear and more...
  3. #3
    Default
    Thanks for your response, so you wish to elaborate? Would I have to go as far as getting a wiring harness from an er model?
  4. #4
    Join Date
    Apr 2003
    Weston WI
    Posts
    9,139
    Blog Entries
    3
    Default
    Quote Originally Posted by David Mcfadzen View Post
    I would have to look over the wire schematic to see whats tied into what. A harness with electric start, I would think could help but there has to be another regulator or something that will limit the mount of charge to the battery so your dont over charge it.
  5. #5
    Default
    It has smoothing condensers and voltage rectifier so I would think I could just tie into those?
  6. #6
    Lifetime VIP Member
    Join Date
    Dec 2007
    georgetown ontario
    Posts
    524
    Default
    The battery (for an electric start sled) is used to start the sled only. Once running, the stator supplies all voltage including replenishing the battery. The voltage regulator keeps the system voltage at approx. 13.5V as to not harm any electrical components. I have installed a battery / electric start on my SRX's with no issues.
  7. #7
    Join Date
    Apr 2003
    Weston WI
    Posts
    9,139
    Blog Entries
    3
    Default
    I wish I new more.. but thats all have. I would get a electrical diagram and go from there.
  8. #8
    Super Moderator super1c's Avatar
    Join Date
    Sep 2003
    Freeland & Otsego lake, MI
    Posts
    5,139
    Default
    For the ease and cost I would just add the electric start. By the time you buy parts and what you need it’s just as easy to buy a nice used kit. The sled is pre wired for the e start so all you need is the harness that plugs into lead by right side foot well and you would have a keyed charging system for a battery.
    2002 Yamaha SXViper - Daughters
    E-start, reverse, extended to 144" with cobra track. Awesome EdgeWrap in purple and pink!!
    2016 Yamaha SRViper LTX-SE - Wifes.
    2017 Yamaha SRViper LTX-LE - Mine
    THE VIPER PIT IS NEVER COMPLETE! Bipolar!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
