LED headlight issues on 98 SRX 700
Not too sure about the HID system in your above post. It appears to be $89 USD + need to mount a converter box under the hood. For H4 LED 30W 12 Volt DC motorcycle bulb, its cost me $24 CDN (thanks Amazon) and I simply connected the Sleds factory reverse buzzer (which is 12 Volt DC Power) to the handle bar's Hi/Low switch. Simple trick and low cost. And, no module to mount / secure under the hood either.
Another question, on a 2001 SRX, with the 300 watt charging system, how does a guy get DC to the hi/low switch?
I’m guessing the srx didn’t have the reverse brown wire?
I replaced my 98 SRX single headlight with the newer dual bulb and I put in cyclops led’s you must put a rectifier for each bulb since it is ac currant to the headlight or it will not work well and will ruin the bulbs. I put a rectifier for each bulb and it has performed flawlessly. The cyclops are super bright. It’s such a difference and well worth it. I would imagine if you found a dc source on the sled that would work too.
