Results 1 to 4 of 4
Thread: 2005 Venture RS
  1. #1
    Junior Member Mini
    Join Date
    Nov 2019
    Wisconsin
    Posts
    2
    Default 2005 Venture RS
    Bought a used 2005 Venture RS last year - 144" track - all stock...2200 miles
    I just put 114 studs on it (down the center) and now am wondering if I need any type of tunnel protection?
    Appears I have plenty of clearance for the exhaust - front by the jack shaft looks like it will clear?
    Getting mixed opinions on whether I need them or not - I see Yamaha sells a kit but another dealer said they came stock with them and the guy I bought the studs from said I did not need them.
    Obviously if I can run safely without them I would prefer to save the $200.
    Under the tunnel it appears to be all protected.
    Bill
  2. #2
    1 out of 1 members found this post helpful.
    Default
    Welcome to the forum, I highly suggest you register on the 4 stroke forum
  3. #3
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,566
    Default
    wlcome to the site.
    x2 on going over to ty4stroke.com . i think studding warning has been covered in the rs section.
    sleds
    540cc workhorse (vk 540)
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of dependability (11 apex xtx)
    1000cc of yamaha excellence ( 16 apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  4. #4
    Junior Member Mini
    Join Date
    Nov 2019
    Wisconsin
    Posts
    2
    Default
    Thanks guys - headed that way.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
