A few 02 vmax 600 questions
So looking like a busy fall this year so not sure how much time I’ll have but I’m looking into removing the electric start on this 02 vmax 600. The previous owner removed ring gear when it came loose and I don’t have it so it hasn’t been used since I’ve owned it. Looking to clean up the under hood area. So if I remove it, I know remove the starter/battery/wiring. So does it all just unplug and then do I need to get a smoothing condenser and it has a plug in somewhere? I’m not looking to splice things in. Or do I need a 02 sxr 600 wiring harness to make it like it never had es? Thanks or does someone have a sxr es install instructions that I could use to reverse the procedures?
you go to the section you want to p;ost in and on the left side there is a tab that is labeled start new post.
