Results 1 to 4 of 4
Thread: Mm600 to 700 info
  1. #1
    Default Mm600 to 700 info
    So long story short I sent the rod of my kids mm600 through the case. So motor is shot really made a mess of everything. Question is I've seen alot more redhead 700 motors than redhead 600s, what would all need to be changed to go to a 700 over the 600? Carbs? Pipe?cdi?
    Sent from my SM-G960U using Tapatalk
  2. #2
    Default
    Quote Originally Posted by sdviper700 View Post
    do some looking at part numbers , when i was looking for carb parts for my 700 i believe i saw that they fit both the 700 and 600 with the only difference being the jetting. it would be cheaper to buy a carb kit containing all the jets and gaskets for a 700. the exhaust is the same between the 2 motors
  3. #3
    Default
    I did a 600 twin to 700 triple swap in mine.
    Easiest way to see what can stay, is go on a parts website and check part numbers to see whats the same.
    Some things that come to mind that may be different:
    Wiring harness/CDI
    Carbs - 600 get a 31mm and 700 get 33 ? cant recall..
    jetting
    clutching
    gearing
    1997 Yamaha XTC
    700 Redhead, Mr. Viper ported, CPR pipes, SRX reeds, Heelclickers, Dual bulb, LT Ohlins
    1997 700 SX
    Thinned head gasket, Gutted Airbox, Reed Spacers, Bender Pipes, Viper Shocks, 51/43 helix 89L weights
    2004 Viper S
    SLP pipes, peak performance head,
    2001 SRX 700
    Power Inc. Pipes, Loaded 8DN20's, Hauck Y 51/45
    1997 Mountain Max 700
    Black XTC Hood, Thinned Head Gasket, Gutted Air Box, Reed Stopper Notch, SLP Pipes
  4. #4
    Senior Member Mod Vincent's Avatar
    Join Date
    Aug 2015
    Ontario Canada
    Posts
    884
    Default
    Wireing should be the same. Carbs are 31 vs 33mm . CDI have different part numbers but I've interchanged them without noticing any difference. Exhausts are the same, as are engine mounts. Clutch weights and spring will be different as will be chaincase gearing.
    Me and my brother own 600 and 700 triple long track Ventures and these have been my observations between them.
    2000 Venture 700
    -Head gasket thinned
    -Stainless reed stoppers notched
    -Cobra 1.35 x 136" track
    -Home made transfer rod
    -Boss Seat
    -Apex helix, 8ch weights, +2.8g per tip, wpw spring, 8dn belt, green sec @ 70
    -22-39 gears with reverse
    -Rox 3" risers
    -Plastic skis
    -Drilled can
    -Electric start system and ring gear removed.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
