Results 1 to 5 of 5
Thread: Clutch buttons/ramp shoe
  1. #1
    Member Mini
    Join Date
    Aug 2018
    New Hampshire
    Posts
    49
    Question Clutch buttons/ramp shoe
    I noticed a broken clutch button on my secondary... 98 SRX 700. Iíve never had to change these before so Iím wondering how they come out and how they go in. Do you just pry them out with a screwdriver? It looks like they just push in. Do I need to put locktite on the new ones before putting them in? Any input would be great
  2. #2
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    6,348
    Default
    Pry or Vice-Grip them. They slide it. No Locktite.
    Dannyboy
  3. #3
    Member Mini
    Join Date
    Aug 2018
    New Hampshire
    Posts
    49
    Default
    Awesome. Thank you
  4. #4
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,579
    Default
    go oe for better button life. aftermarket ones might be good for a season if you are lucky.
    sleds
    540cc workhorse (vk 540)
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of dependability (11 apex xtx)
    1000cc of yamaha excellence ( 16 apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
  5. #5
    Senior Member Open Mod Vincent's Avatar
    Join Date
    Aug 2015
    Ontario Canada
    Posts
    1,019
    Default
    Just changed some today. You can punch out the old ones threw the back.
    2000 Venture 700
    -Head gasket thinned
    -Stainless reed stoppers notched
    -Cobra 1.35 x 136" track
    -Home made transfer rod
    -Boss Seat
    -Apex helix, 8ch weights, +2.8g per tip, wpw spring, 8dn belt, green sec @ 70
    -22-39 gears with reverse
    -Rox 3" risers
    -Plastic skis
    -Drilled can
    -Electric start system and ring gear removed.
    -LED headlight and tale light
Posting Permissions
  • You may not post replies
  • You may not edit your posts
