Results 1 to 6 of 6
Thread: Water Pump impeller
  1. #1
    Default Water Pump impeller
    I have a 2002 viper. I am trying to remove the impeller on the water pump. I have already removed the bolt, is there a trick on removing the impeller.
    Thank's in advance
    Rich
  2. #2
    Lifetime VIP Member
    Join Date
    Dec 2007
    georgetown ontario
    Posts
    527
    Default
    H E A T and lots of it! It's an ugly job, good luck!!!
  3. #3
    Default
    Thank you for that information. Does anyone else have a trick to remove the impeller from a 2002 Viper. Looking at different options here.
  4. #4
    Lifetime VIP Member
    Join Date
    Dec 2007
    georgetown ontario
    Posts
    527
    Default
    In true Yamaha fashion, they use a VERY strong compound on the splines of the shaft that mate with the impeller. Heat (lots of it) and pulling up from backside of impeller will allow removal. If there is a different method to complete this job, I'm all ears!!!
  5. #5
    Default
    Quote Originally Posted by northern srx View Post
    I understand the heat procedure but how can you pull up from the back side of the impeller if the impeller is almost flush with the case itself.
  6. #6
    Default
    Quote Originally Posted by TrueBlue View Post
    The way I got the impeller off was pretty easy. I used a heat gun & 2 very small screwdrivers & pryed up on the impeller at different locations.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
