Results 1 to 4 of 4
Thread: replace PTO bearing race
  1. #1
    VIP Lifetime Member fourbarrel's Avatar
    Join Date
    May 2003
    Posts
    2,690
    Default replace PTO bearing race
    Has anyone ever successfully got the press on race from the PTO end bearing of an SRX crank off without damaging it? I have a good crank that needs the PTO bearing race replaced as I'd say this one sat with moisture in the bearing and it pitted the race and the only way to get a new race is to buy the whole bearing assembly to the tune of $465 Canadian. I have another crank with a bad centre rod but if I could get the race off the PTO end I could put it on the other crank,otherwise I will have to send both cranks to a machine shop to have them completely pressed apart to have the PTO end swapped.
    I'll be right home honest.
    Looks like the couch again tonight.
    If I have to explain it you wont understand.
    SLED MODS:
    98 SRX 700
    reverse
    8DN-20s w/4.5g both holes and Apex helix
    Cobra w/s
    Apex skid
    Rox riser
    Powermadd handguards
    extended brake hose
    Pilot skis
    2000 electronics
    Boss seat
    2001 SRX 700
    Bender trail ported
    Boyesen Rage Cages
    8DN20s w/54-46 Dalton
    21/38 gearing
    Rox riser
    Powermadd Sentinel hanguards
  2. #2
    VIP Member A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    6,361
    Default
    I'd try freezing the crank in the chest freezer. Once your press is configured correctly, go get the crank and place it in there. With a fine tipped brazing torch, heat up JUST the bearing.
    Dannyboy
  3. #3
    Join Date
    Jan 2009
    Posts
    6,361
    Default
    After thinking about this, the temper on the bearing after the above process would be AFU. If it was an easy bearing to get to, I'd do it. Not on a crank bearing.
    Dannyboy
  4. #4
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,596
    Default
    you could try supporting the bearing and use dry ice on the crank to make it shrink out of the bearing.
    sleds
    540cc workhorse (vk 540)
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of dependability (11 apex xtx)
    1000cc of yamaha excellence ( 16 apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
Posting Permissions
  • You may not post replies
  • You may not edit your posts
