Replacement skis for an ovation
enticer II, phazer I & II, vk 540 (plastic or steel) are all pretty much bolt up with no mods.
with a couple of washers and a longer bolt, sr viper and sidewinder skis bolt up. should be some take off ones floating around. this is what i run on my 97 et410.
you can also use the saddle type sxr 500/600/700 plastic skis with washers and the long bolt if you can find a set.
you can also use the saddle type sx viper/venom or rx1/warrior skis with an added shim mod as listed on the site with washers and a longer bolt.
GOT THIS DONE! I took a pair of SRX skis and machined out the saddle to fit the Ovation leg. Had to buy a set of full size VMAX collars and trim them to the width of the SRX ski and make spacers. WORKS GREAT!
