2002 vamx temp warning light on why?
rkkoeb
Green Bay
So I am working on a 2002 vax 600 that has the temp warning light on. I have flushed the coolant and even changed out the temp sensor on the top of the engine but the light keeps coming on. Any suggestions on what to look at next or try?
If it only does that during startup things are ok. It's just checking the system.
Can you describe the pattern better?
Water temp circuit problem is 1 long flash 3 short flash
Variable switch for thumb warmer is 3 long flashes, then repeat.
