So I am working on a 2002 vax 600 that has the temp warning light on. I have flushed the coolant and even changed out the temp sensor on the top of the engine but the light keeps coming on. Any suggestions on what to look at next or try?
Is it flashing a pattern or just on steady?
Looks like it flashes 3 times
It keeps doing that all the time or just when you start it?
If it only does that during startup things are ok. It's just checking the system.
02 SRX 700. 22/38, 50/40, belly pr, MM skis, Mx perf tr rods, TPI valves, temp gauge, HC
01 MM 700. Reeds mod, hauck gasket, 44/38, tr enh kit, temp gauge, bellypan protector.
99 VT 600. European edition. Cargo rack & box, tow hitch, 50/38
97 VT 500.Tempaflow, dupont, belly pan protector, 41, HC, tow hitch.
97 SX 600. SRX rear HE. Hauck X weights, 39 h, dupont, 22/39, bwb prim spring.
Keeps flashing
Any thoughts on what this could be?
Can you describe the pattern better?
Water temp circuit problem is 1 long flash 3 short flash
Variable switch for thumb warmer is 3 long flashes, then repeat.
