Results 1 to 2 of 2
Thread: Carb removal and install in Phazers and Exciter 570's
  1. #1
    Default Carb removal and install in Phazers and Exciter 570's
    I have done this at least a dozen times and I am wondering if there is any easier way. In either case I unfasten the retainers for the air box, Phazer the one of two bolts under the dash, and in the case of this Exciter I am working on, there are two I believe, under the dash and another close to the brake caliper. Either way, there still isn't sufficient clearance to pull these carbs without mangling or dropping clamps into the belly pay. I am looking at possibly pulling the motor mounts just slide the engine forward.
    So if you have any suggestions, the backs or my hands look like hamburger, and I'd really like to make this easier if at all possible.
  2. #2
    Super Moderator Maim's Avatar
    Join Date
    Mar 2004
    sudbury on. canada
    Posts
    3,700
    Default
    following. about to have to do this to finish a project one started 15 years ago.
    sleds
    540cc workhorse (vk 540)
    410cc reliable power (enticerII) rx tunnel braces
    500cc mutant margarita mixer (09 phazer rtx/x)
    1000cc of dependability (11 apex xtx)
    1000cc of yamaha excellence ( 16 apex xtx)
    motorcycle's
    00 xt350 mod
    08 wr250x
    atv
    2005 big bear pro
Posting Permissions
  • You may not post replies
  • You may not edit your posts
