2006 Apex GT - No Spark
LaTray80
NY
I have a 2006 Apex that will not start. Sled ran over the summer but went to fire up a couple days ago and battery was flat. Hooked up a jump box and sled rolls over but doesn't fire, no spark. Can hear the fuel pump turn on when ignition switch is turned on. That seems to be working properly. Checked fuses and do not see any blown. There are also no error codes displayed. Was wondering if someone has had a similar problem and what to check next.
I also checked the ignition relay as I did hear a couple clicks but warmed relay up and seems to be working properly now. I even swapped the relay out with another but same results. Any help is greatly appreciated.
you need to go to ty4stroke.com and post this question in the apex section. much more knowlege on 4 stroke stuff there.
