Results 1 to 4 of 4
Thread: Rear suspension is more on the right side
  1. #1
    Senior Member Open Mod norwegian's Avatar
    Join Date
    Nov 2004
    norway
    Posts
    2,744
    Default Rear suspension is more on the right side
    Hi
    My friends srx has the rear suspension more on the right side than the left, making the track not centered on it. The drive sprockets have been checked, they are on the shaft within spec. The track has the same clearance on each side up by the drive axle. When the rails begin there is less clearance on the right side than on the left, and is so throughout the length of the slider, what gives? What causes this? Saw this is the case with my 99 venture 600 also, but it has track clips with no guides on them, so they do not destroy the plastic slider.
    Any ideas?
    02 SRX 700. 22/38, 50/40, belly pr, MM skis, Mx perf tr rods, TPI valves, temp gauge, HC
    01 MM 700. Reeds mod, hauck gasket, 44/38, tr enh kit, temp gauge, bellypan protector.
    99 VT 600. European edition. Cargo rack & box, tow hitch, 50/38
    97 VT 500.Tempaflow, dupont, belly pan protector, 41, HC, tow hitch.
    97 SX 600. SRX rear HE. Hauck X weights, 39 h, dupont, 22/39, bwb prim spring.
  2. #2
    Senior Member Open Mod roudyroy1's Avatar
    Join Date
    Jan 2013
    ontario GTA
    Posts
    1,517
    Default
    check the w- arm for bends / breaks
    a wise man from canada once told me
    "there are only 2 types of sleds. 2 STROKES and 4 JOKES" !!!
  3. #3
    Default
    Bearing behind the speedometer drive most likley the culprit.
    That is usually what happens when the track adjusters wont bring the track back to center.
    1997 Yamaha XTC
    700 Redhead, Mr. Viper ported, CPR pipes, SRX reeds, Heelclickers, Dual bulb, LT Ohlins
    1997 700 SX
    Thinned head gasket, Gutted Airbox, Reed Spacers, Bender Pipes, Viper Shocks, 51/43 helix 89L weights
    2004 Viper S
    SLP pipes, peak performance head,
    2001 SRX 700
    Power Inc. Pipes, Loaded 8DN20's, Hauck Y 51/45
    1997 Mountain Max 700
    XTC Hood, Thinned Head Gasket, Gutted Air Box, Reed Stopper Notch, SLP Pipes
  4. #4
    Join Date
    Nov 2004
    norway
    Posts
    2,744
    Default
    Thanks, what is happened to the bearing? Internals off place?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
