Interchange on suspension parts
If you have a Rx1/vmax xt/venture/rage/worrior, your sleds shocks and side arms do not have bearings in them. For the rage and worrior,buy the arms from below and remove the bearings and seals. You will need to ream out the side arm ends about 1mm to accept the bearings and seals. For all others you can just buy a used set from a viper/sx/srx/xtc and install them.
Will the bearings and seals fit into the side arms that originally had the bushing setup? I looked at the parts fiche and the part number for a Viper with the bearings in the side arms is 8CX-47494-01-00, and the part number from my sled with the bushing setup is 8CR-47494-01-00. Just wondering if I could just buy the bearings/seals or if I'd need the actual arms too.
