Page 12 of 12 FirstFirst ... 2101112
Results 111 to 115 of 115
Thread: 99 sx transformation
  1. #111
    Senior Member Open Mod musselman's Avatar
    Join Date
    Oct 2008
    Sunderland, Ontario
    Posts
    1,017
    Default
    I used cables from an 03 viper mountian, the rsi cables were crap, very rough and hard to pull.
  2. #112
    Junior Member Mini Alex Petersen's Avatar
    Join Date
    Oct 2016
    Stillwater MN
    Posts
    5
    Default
    hmm maybe i should try and re rout the cables. i already have them going through the air box. or maybe tilt my risers and bars more forward?
    have you heard of spi extended cables?
    https://www.ebay.com/itm/381800568503
  3. #113
    Join Date
    Oct 2008
    Sunderland, Ontario
    Posts
    1,017
    Default
    I have never used them so can't say but they will be better than the extensions at least. Viper mountain cables will be the best though.
  4. #114
    Join Date
    Oct 2016
    Stillwater MN
    Posts
    5
    Default
    don't mean to hijack your thread but I've got some questions about lifting the front of my 2000 sxr 700. since this was the year they made the long travel suspension, how do i go taller? I'm pretty sure the viper shocks are the same size. ive done a lot of researching and i can't seem to find a longer shock that will bolt in. I've read somewhere that rmk shock fits but i don't have the older style bulkhead with the eye lit mounting holes. thanks!
  5. #115
    Join Date
    Oct 2016
    Stillwater MN
    Posts
    5
    Default
    i cannot seem to find the shock brackets you are running. I'm very interested in them since they raise the front even with smaller shocks.
    are these the brackets?
    http://www.sno-tek.com/product_files...r%20Yamaha.htm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
