Junior Member
Mini
apex error codes
I'm new here and seen a post with the error codes for a 07 apex. Unfortunately I can not find it any where. Could someone please send the diagnostic code list for that sled. Thanks in advance. Lee
Senior Member
Stock
Junior Member
Mini
I found that one but it was not the same one I was looking for. The one I needed was the one that showed the diagnostic fault codes. My buddys sled was flashing 22 with the engine light on. The first two times I looked at this site I seen it but for some reason I can't seem to find it again. Thanks for the help though........
Mini
http://www.ty4stroke.com/viewtopic.php?t=36172 I would check the plug going in to your airbox
Junior Member
Mini
I had error code 1 on my 2006 Apex, was starting and running fine before them BAM, nothing, no power only relay clicking. ******Check your battery first******* mine was showing a good voltage but was faulty. Replaced battery and all was good.(but that was after I went through all the wiring, relays and fuses LOL)
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
